4x4 saph cossie revving
Old Jan 17, 2005 | 09:11 AM
hodgie's Avatar
hodgie
Default 4x4 saph cossie revving
Can anyone point me in the right direction my 4x4 Saph Cossie, Revs by it's self on idle. Normally upto about 4500rpm then dies back down and idles nicely , it mainly does it when cold but occasionally while warm, is really annoyiny can Ne body help......
cheeRS..
Old Jan 17, 2005 | 07:44 PM
CosKev3's Avatar
CosKev3
Easiest option is to take it to a good cosworth tuner m8
Get it on the diagnostics and good set-up/tune
Old Jan 17, 2005 | 07:59 PM
abdr500's Avatar
abdr500
it can e a few things first your tps could be playing up second could be you idel control valve iscv it can be the litel blue sensor at tyhe back of the head that controls the idel iscv and the fueling first un plug the tps and see if it still does it not then change that if it make s no differnce then change the blue sensor at the back off head but un plug the iscv first that might be no good now
Old Jan 18, 2005 | 01:24 AM
hodgie's Avatar
hodgie
iscv? tps ?
Old Jan 18, 2005 | 01:26 AM
hodgie's Avatar
hodgie
oh and i forgot to mention it does'nt do it all the time..
Old Jan 18, 2005 | 01:54 AM
pugo's Avatar
pugo
iscv...idle speed control valve
tps ....throttle position sensor
Old Jan 18, 2005 | 02:54 AM
hodgie's Avatar
hodgie
CheeRS m8.
tib2220
Sep 14, 2015 12:33 PM
dojj
28
Sep 11, 2015 10:00 PM
truffleshuffle
Sep 10, 2015 09:35 PM
Escortdriver1
Sep 6, 2015 10:12 AM
Adam Graham
Sep 6, 2015 06:04 AM
