Replacing Rear Brake Pipe
Old Jun 2, 2010 | 09:33 PM
DansGTi's Avatar
DansGTi
Default Replacing Rear Brake Pipe
'99 Fiesta failed its MOT today on a corroded rear brake pipe. Is this a home DIY job or should I get some garage quotes? If this is do-able at home is there any guides available to help me?
Old Jun 2, 2010 | 09:40 PM
James998's Avatar
James998
If you're not 100% on what you're doing I wouldn't chance it, especially where brake pipes are concerned.
It's an easy enough job if you know what you're on with. O/S/R is the easiest side, no need to drop the tank there is just enough room.
Old Jun 2, 2010 | 10:06 PM
DansGTi's Avatar
DansGTi
probably best i get a few quotes then! is it an expensive job?
Old Jun 3, 2010 | 06:18 PM
Should only be a few £'s for a new copper pipe, then 1 hours labour is way more than enough.
Ask around in the local car shops, they're sure to know someone who will do it cheap for you for a bit of cash.
original
Apr 28, 2026 05:20 PM
s1cab
Jul 26, 2018 06:11 PM
track.focus'd
Aug 12, 2015 05:53 PM
Bosch
Aug 4, 2015 05:14 PM
