Changing coilpack Focus for an Escort one?
Old Apr 7, 2010 | 07:59 AM
YBJ's Avatar
YBJ
Thinking Cosworth..
Default Changing coilpack Focus for an Escort one?
The coilpack on my Focus 2.0 ('02) has started to fail. I replace it for an escort zetec item which has the same connector and it runs sweet now. Just needed the leads too to get it installed. It wont fit at the focus bracket so I'll think I need the escort bracket as well.
But my question is can this swap do any damage to the Focus PCM (ECU)?
Old Apr 7, 2010 | 01:10 PM
I would only guess that the resistance is going to be very similar across the coilpacks, in which case it's fine, as it's that that will hurt the ecu if anything.
Old Apr 7, 2010 | 01:47 PM
YBJ's Avatar
YBJ
Thinking Cosworth..
Thanks Tabetha, that's what I thought too . What I have heard is that when using bad sparkplugs or HT leads the high voltage would damage the inside of the Focus coilpack. Something that I have never heard about the old Zetec ones.
So now I made up the Focus bracket so that it can have the old zetec coilpack. Bloody hard to do... The best thing you can do is find yourself a old zetec bracket. At this both old and new coilpacks will fit!
Old Apr 7, 2010 | 02:27 PM
grcossie's Avatar
grcossie
The problem whit this first kind of coilpack, is that to big plug gaps, break them. The newer ones are better. I have change alot of this
Old Apr 7, 2010 | 04:56 PM
YBJ's Avatar
YBJ
Thinking Cosworth..
Do you mean the first ones that came with the Focus?
Vincereese
Jun 1, 2023 09:14 AM
salsheikh
Ford Focus ST Parts for Sale
Oct 6, 2019 07:56 PM
salsheikh
Ford Focus RS Parts for Sale.
Aug 20, 2015 12:22 PM
Vincereese
Aug 18, 2015 03:57 PM
Vincereese
Aug 16, 2015 06:38 PM
