mondeo tdci knocking noise
Old Apr 1, 2010 | 04:04 PM
ian321's Avatar
ian321
Default mondeo tdci knocking noise
just bought 55 plate mondeo 130 tdci. when engine is cold distinct knocking noise is heard. Fuel filter recently changed and diesel treatment, which makes me wonder if it is related to problem? Help?
Old Apr 1, 2010 | 04:50 PM
nellyscossy's Avatar
nellyscossy
what kind of knocking..it isnt the dual mass about to go bang is it
Old Apr 1, 2010 | 05:32 PM
p285e's Avatar
p285e
If it 's 1500 rpm it could be the injectors they are noisier when the engine was cold beetween 1500 and 2000 rpm
Old Apr 1, 2010 | 06:08 PM
Dave2302's Avatar
Dave2302
Tranny Man
Yeah, I'd go with Injector noise, (well diesel knock). They run more advance on the pump when cold to smooth out the idle and clean up exhaust emissions.
Also sometimes the injectors need resetting on a decent scanner, had to do one I bought to sell a couple of years back
HTH
Regards Dave
Old Apr 1, 2010 | 06:22 PM
steanlol's Avatar
steanlol
Mondeo's are notorious for their injectors going between 60k and 70k , mine luckily enough lasted till 148k due to motoway mileage .
I'd get along to a proper delphi agent , have the injectors taken out and put on a flow test and you'll know one way or another .
My car needed 4 new injectors and total cost was Ł692 after labour and recoding and removal and refitting and the car is like new now .
Good luck , check out www.fordmondeo.org as well
Old Apr 1, 2010 | 07:53 PM
steve4i's Avatar
steve4i
it's not nocking when you rev it is it hasnt lost any power either?
Old Apr 1, 2010 | 08:41 PM
ian321's Avatar
ian321
Default mondeo knock
thanks guys
there is no lose of power, guying well local mechanic thought tappits then advised me to see diesel specialist, it is atappit type noise only when cold or low revs. hope it is not injectors
Old Apr 1, 2010 | 09:14 PM
p285e's Avatar
p285e
if the engine is 130 bhp tdci you have just a hugh preassure pompe because it's a common rail, I don't think that's a advance problem
if the engine turn well at the idle on his four cylinder I don't think that you have a problem with the injectors
I have the same car and when I'm at low revolution the engine knock a little but it's normal I have the same noise with the Mondeo of my customers
But take some advise to a local diesel specialist
Let we know the diagnostic
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
wowk
Mar 30, 2021 07:49 PM
Brickhouse
14
Oct 3, 2015 07:28 PM
gingeRS
17
Oct 2, 2015 09:42 AM
The Enigma
Sep 29, 2015 10:31 AM
