Starter motor
Old Mar 14, 2010 | 08:31 PM
eoeumc's Avatar
eoeumc
It's ALIVE..Well sort of!
Default Starter motor
Hi peeps
I have been told by a couple of people that the cog in the starter motor is supposed to spin quite freely both ways by hand!
I was told today that they are not! I was given this starter motor tonight and it does the same as my one and only spins 1 way.
Which is it?
Both ways or just one way?
Thanks
Old Mar 14, 2010 | 09:26 PM
steve4i's Avatar
steve4i
only spins one way as it push's it's self out when you crank the it over
Old Mar 14, 2010 | 09:29 PM
botters's Avatar
botters
competant bodger
yeah only spin free one way
Old Mar 14, 2010 | 09:35 PM
What they said one way, if it spun both ways it wouldn't turn the engine over!!
It freewheels one way so when started the ring gear doesn't overspeed the starter, whilst you release the key.
Old Mar 15, 2010 | 11:52 AM
eoeumc's Avatar
eoeumc
Thank you peeps
So I now have another question.
If I can turn the pully's via the bottom pully and when I turn the key it just clicks (rather loudly) what else could be the culprit of the car not starting?
Its getting a bit confusing now
Old Mar 15, 2010 | 12:18 PM
base190380's Avatar
base190380
sounds as though either the attached solenoid is fault or the main heavy red live wire is broken from the battery to the starter
Old Mar 15, 2010 | 12:58 PM
eoeumc's Avatar
eoeumc
I disconected the live wire from the battery and run a seperate wire from the live terminal to the sarter motor and it still clicked.
Old Mar 15, 2010 | 05:29 PM
Is it a bosch starter ?
Could be a few things, instead bridge the terminals from the battery(input) and output to the motor, with a 50p or similar, does the motor spin, it won't engage as the solenoid has not been activated.
If it spins it may be ok, and could just be a stuck solenoid, then try a wire direct from the battery input to solenoid direct onto the wire where the ignition feed goes.
It sounds as though power is not getting through fully, plenty voltage but not enough current, sometimes the solenoid terminal builds up a high resistance, so doesn't hold the solenoid contacts(inside) firm enough to bridge the contact points inside for current to flow across into motor part.
Sometimes the laquer comes off flakes off the solenoid piston surround, the "tube" effectively surrounding the solenoid piston causing it to jam, normally worse when hot if this is the case, roll some old knackered 1000grit wet and dry paper in a roll, so the rough side is outer most, oil it and clean the inside of the solenoid to remove all the loose flaky pieces, drench afterwards with wd40 or similar, and dry out, will be perfect for another few years after that.
Old Mar 15, 2010 | 07:42 PM
eoeumc's Avatar
eoeumc
I will try what you have suggested tomorrow in the day ligh Tabetha
But I did try to use a wire direct from the negative terminal and the positive terminal on the battery direct to the starter motor. Now I don't know if this would do anything or not, but nothing happened! No click, no spark no nothing. I have put the battery back on charge again and I will see what will happen tomorrow, but would anything happen with direct terminal contact?
Old Mar 15, 2010 | 08:29 PM
tbh it's very hard to get a good enough contact using jump leads.
At the worst it will need new brushes, very easy to do, around Ł10-Ł15 then gently undercut armature grooves, on some you just replace the whole brush box as it is cheaper, the worst thing that can happen is the nose cone bearing seizes, but as spinning it's not this.
Old Mar 15, 2010 | 10:32 PM
eoeumc's Avatar
eoeumc
So best thing to do is to put it in the engine and hook the battery up properly?
Not a problem
Thank you
Old Mar 16, 2010 | 12:33 PM
eoeumc's Avatar
eoeumc
Well I put the newer starter motor on this morning and connected the battery back up and turned the key!
It turned over I am happy now as the worse wasn't true
Just got to change the matrix over now lol
bobsworth
77
Mar 24, 2016 09:30 PM
A.t.p
Oct 23, 2015 07:54 PM
cossie362
Oct 11, 2015 03:53 PM
Shaunc
Escort Range
Sep 23, 2015 06:00 AM
marky_g
Sep 12, 2015 04:26 PM
