Focus Idle Valve?
Old Mar 14, 2010 | 04:25 PM
matt24680's Avatar
matt24680
Default Focus Idle Valve?
hi there i have a 1.8 zetec focus 1999 and wheni rev the engine the revs drop to 1500 then drop to 1000 like its sticking iv already checked the cable and body when rev it with my hand beside the tb it does the same thing is it the idle control valve?
thanks
Old Mar 14, 2010 | 04:39 PM
H3lsing's Avatar
H3lsing
ffoc.co.uk
Any misfiring? go ahead and clean the ICV and MAF sensor. Use electrical contact spray on MAF though and don't touch it. These would be the cheapest things to try first. Let me know if you need diagrams.
Old Mar 14, 2010 | 04:43 PM
matt24680's Avatar
matt24680
hi there thanks for the reply iv already bought a new icv from ebay for £25 but i will try to clean maf first and see what happens doesnt misfire. can i start up the enigne without maf for a sec to see if it is the problem?
thanks for the help
Old Mar 14, 2010 | 04:51 PM
H3lsing's Avatar
H3lsing
ffoc.co.uk
Yep, you will hear a difference in revs etc if it's faulty. Ford will tell you to spend £40 or so on a new MAF. They are fine with a good cleaning though. Might be an idea also to check for vaccum leaks from hose going to airbox. This can cause idle probs too.
Old Mar 14, 2010 | 04:58 PM
matt24680's Avatar
matt24680
will do thanks for the help!
Old Mar 16, 2010 | 07:30 PM
matt24680's Avatar
matt24680
hi there i the rev problem went away wen the car warmed up but wen i accelerate fast and change gear the throttle sticks like takes a while do come down in revs wen i push in the clutch only wen accelerating fast any ideas maf this time??
thanks
Old Mar 16, 2010 | 07:44 PM
H3lsing's Avatar
H3lsing
ffoc.co.uk
I think you should come over to http://focusowners-social.com/forum and register. These problems are discussed everyday there. It's a focus only site and some good people on there.
Ford Focus RS Parts for Sale.
Mar 9, 2016 01:03 PM
Nov 5, 2015 08:12 PM
15
Oct 7, 2015 03:43 PM
xrmalin
Sep 13, 2015 06:52 PM
cossirob
Sep 3, 2015 09:17 PM
