2000 ford galaxy 19tdi problem
Old Mar 13, 2010 | 05:59 PM
petenete's Avatar
petenete
Default 2000 ford galaxy 19tdi problem
cut a iong story short my galaxy has just had a new engine fitted and it is smoking bad. bluey white and stinks of diesel. so pulled exhaust off at the turbo and diesel is leaking out the turbo into the exhaust. could this be the injectors or timing out has i put a timing belt on while the engine was out but im sure this was okey anyone any ideas or is this a duff engine
Old Mar 14, 2010 | 10:28 PM
markk's Avatar
markk
is this running the VW PD engine pal ?
Old Mar 14, 2010 | 10:36 PM
steves24V's's Avatar
steves24V's
think it should be a pd engine on that year think that was the only diesel they did, does it miss fire at all? if its missing could e the injector loom in the head and also check the cam rockers and top of the injectors. plus as said timing.
Old Mar 14, 2010 | 10:41 PM
as355f1's Avatar
as355f1
i would say pump timing is out
Old Mar 15, 2010 | 10:48 PM
petenete's Avatar
petenete
yea m8 pd engine tried the injector loom still same. also double checked the timing. funny thing is this started to happen with the old engine then it over heated and cracked the block so i put new engine in now this one smokes as well but the smoke smells of diesel and when i take exhaust off at the turbo diesel drips out the turbo constantly tried everything thnks for replying back
Old Mar 15, 2010 | 11:07 PM
markk's Avatar
markk
are you getting diesel in the oil ? my PD cracked the head around the injector seals and filled the sump with fuel and then sent it down the exhaust
Old Mar 16, 2010 | 08:45 PM
petenete's Avatar
petenete
no diesel in the oil m8 just in the exhaust but like i said the other engine did this aswell
Zoggon
Aug 10, 2015 10:39 AM
