towbar wiring
Old Mar 11, 2010 | 05:44 PM
colin1's Avatar
colin1
Default towbar wiring
Hi
Can anyone tell me what the colours of the wires to the rear lights are on a mk7 (59 plate) fiesta ?
I have to fit towing electrics, & haynes dont do a manual for the mk7 yet
Old Mar 12, 2010 | 07:30 AM
base190380's Avatar
base190380
doddle google trailer socket wiring diagram and get out a mulitmetre and away you go not very hard only 7 wires in total
Old Mar 12, 2010 | 07:46 PM
colin1's Avatar
colin1
yes I know I could do that, but just wondered if anyone could save me some time if they know the colours ?
Old Mar 13, 2010 | 10:38 AM
I'd be surprised on that age car if it wasn't plug and play, ie ford left a socket there for towbar leckies to be simply plugged into, I'd be tempted to investigate this first, lot less hassle.
I don't know the wire colours on your car, but even if I were given the colours it would be best to double check, ford do like to change things, with that being the case if noe asy plug solution metre would be your best mate, also do you have any bulb failure warning in the car, if you do will need a bypass relay to prevent the lights showing when towing.
Old Mar 13, 2010 | 03:13 PM
colin1's Avatar
colin1
Thanks, thats very helpful, I will check if there is a socket under the boot carpet
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
Nov 1, 2015 06:53 PM
Mark RS
Oct 12, 2015 06:01 AM
IainRS1700T
Sep 25, 2015 06:44 AM
ward1174
Sep 12, 2015 03:34 AM
