Cooling fans
Old Mar 1, 2010 | 10:57 PM
Ollie L's Avatar
Ollie L
Default Cooling fans
Hi, my cooling fans seem to have stopped working on my Sapphire Cosworth i was wondering if anyone could tell me which relay it is in the fuse box for them??
Any help would me most appretiated as im still quite new to the Ford world!!
Old Mar 2, 2010 | 07:28 AM
Thanks your luck that your engine is still in one piece first!!!
The fan circuit desperately needs junking, they usually melt the fuse positions due to heat.
Best and only safest way is to rewire the fan circuit, totally seperately, you can get fan loom kits, but easy diy if wanted.
Old Mar 5, 2010 | 11:55 PM
Ollie L's Avatar
Ollie L
Cool, ive ordered one of those loom kits now to sort it.
Cheers for the advice matey.
Old Mar 6, 2010 | 11:32 AM
No probs, pf is here to help everyone.
Old Mar 8, 2010 | 07:04 PM
moondust-saph's Avatar
moondust-saph
moonstone-saph
my fans also do not work, im 21 and had my cossie 4 months but yet to get it ready for the road, i was going to run a feed through a fuse to a relay and then to a switch and then to the fans, so im in control of them manually is this a good idea?
Old Mar 9, 2010 | 07:23 AM
martysmartie's Avatar
martysmartie
No a fan OVERRIDE switch can be a good idea but it's an automated system for a reason. You are on the right track take a feed direct from battery via 30A fuse to a SPST relay, you will need another live feed for relay as well then ground relay into one side of fan switch and run two wires to live of fans themselves and connect to switched live side of relay. Make sure the right you use is the right gauge otherwise the power the fans draw will melt piddy wire.
It's actually surprising if fans do work on original wiring if you were to look in your fusebox I bet there is a melted 30A fuse/holder there. Also the fuel pump wiring degrades over time so it's worth rewiring this as well.
Martin
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
Chas
Oct 5, 2015 07:13 PM
rs_jim
Oct 3, 2015 11:37 AM
simonmcf
Sep 22, 2015 08:40 AM
mk1focus
Ford Fiesta
Sep 21, 2015 05:46 PM
