another turbo question
Old Feb 28, 2010 | 08:43 PM
taittsierra's Avatar
taittsierra
Question another turbo question
can anybody tell me wat determines the rev the turbo starts to kick in at??
thanks in advance>evan
Old Feb 28, 2010 | 11:09 PM
taittsierra
bump!
Old Mar 1, 2010 | 02:50 PM
Air speed, once the turbo, which is a air compressor, supplys a air speed that is higher than that generated by the engines suction on it's own it is said to be boosting, as in amplyfying the air as it is producing more than the engine could command without it purely by the suction created by the pistons moving down.
Small turbo small lag, big turbo big lag, though the advent of roller bearing turbos has addressed this issue of lag to a large extent, so you can now have a big turbo with a lot less lag.
Old Mar 1, 2010 | 04:16 PM
gavintwopies's Avatar
gavintwopies
also size of turbo to engine capacity driving it as the amount of exhaust gases will be greater on a larger capacity engine so will spin up a turbo quicker than the same turbo bolted onto a engine with 500cc less capacity
ie:
std t3 on 1600cc cvh turbo engine about 3.5k revs
std t3 on 2100cc zvh turbo engine about 2.5k revs
this is what i found quite some time ago
Old Mar 1, 2010 | 04:44 PM
Red16's Avatar
Red16
ie:
fuckin hell gav... where you been hiding?
Old Mar 1, 2010 | 05:07 PM
taittsierra
so buy porting the exhuast manifold the turbo will come on boost sooner?is this rite or have i got it wrong??thanks for replying>evan
Old Mar 1, 2010 | 05:34 PM
xr2wishy's Avatar
xr2wishy
Bodger of Blackburn
by porting the exhaust ports you may get a bit more lag, but more flow at the top of the powerband.
basically if you want it to spool earlier fit a smaller exhaust housing, but you will compromise top end power.
a bigger housing means more lag but more potential power at smaller boosts.
it is always a compromise, even with variable vane turbos and roller bearings, just not as much as a "regular" turbo.
Old Mar 1, 2010 | 10:26 PM
taittsierra
alrite i undersand now mate.thanks for the explenation.my turbo works alrite as it is just never understood about dat part!thanks>evan
Matt Baxter
Sep 16, 2015 08:30 PM
s1turboman
Aug 29, 2015 04:27 PM
Marcus L
Aug 29, 2015 02:18 PM
A.t.p
Aug 15, 2015 11:37 AM
Michael Wisbey
Aug 14, 2015 11:57 PM
