koni rear shockers
Old Feb 22, 2010 | 06:12 PM
saph_Al's Avatar
saph_Al
Default koni rear shockers
ok think that one or my rear shocks on the saph may be set harder than the other , problem is that there
appers to be no stop on the adjuster so i cant tell how firm it's set aganst the other . is there a way to do it or am i just bein a think t**t
Cheers in advnce Ally
Old Feb 22, 2010 | 06:25 PM
kawi-mad's Avatar
kawi-mad
didn't think koni rears were adjustable
Old Feb 22, 2010 | 06:29 PM
wayne dowling's Avatar
wayne dowling
theres only to settings on them soft or hard press the button twist & let go then tist sum more till it locks in place hope this helps
Old Feb 22, 2010 | 06:31 PM
m4tt274's Avatar
m4tt274
myn rear konis werent top adjustable but they had like 7 settings.
Old Feb 22, 2010 | 06:32 PM
col93saphcos's Avatar
col93saphcos
on mine when you push wee button in and turn the piston/ram it clicks,has three settings i chose middle so knew both were same,maybe differant from yours,can soon look for instructions see what way gives you what if you like
Old Feb 22, 2010 | 06:46 PM
saph_Al's Avatar
saph_Al
yeah they have a button under the boot that u push in and twist the leg. on the pic i shows three settings but theres no sopper the just kep clicking as u turn so how do i know what setting there on ?
Old Feb 22, 2010 | 06:54 PM
col93saphcos
each click is the setting,when it clicks release button and thats it set,when button is up ram just spins with no clicks
Old Feb 22, 2010 | 06:58 PM
col93saphcos
just re read it,mine doesnt keep spinning right round if button is in,would get 1 click in middle other 2 can only turn it a wee bit past click
155lee
Sep 6, 2016 11:10 AM
S3an
Sep 26, 2015 11:39 PM
The Enigma
Sep 12, 2015 10:12 PM
truffleshuffle
Sep 10, 2015 09:35 PM
cossirob
Sep 3, 2015 09:17 PM
