Mk3 Fiesta Clutch Problem
Old Jan 20, 2010 | 07:35 PM
JamesyRS's Avatar
JamesyRS
Default Mk3 Fiesta Clutch Problem
Hi guys,
My clutch is having problems on my mk3 fiesta, its the pedal not the clutch itself. U can push pedal and select a gear but then next time u push the pedal nout happens u may have to push a few times or just once it clicks and then has the clutch activating again just wanting ideas I think it may be the ratchet? Are these self adjusting or do you have to do it manually? Thanks
Old Jan 20, 2010 | 09:33 PM
AndyST's Avatar
AndyST
Sounds like a new ratchet and pawl is needed, you can do a temp repair by fitting a 1/2" spacer in between the cable and the gearbox, may not last long though.
Old Jan 21, 2010 | 03:38 PM
JamesyRS's Avatar
JamesyRS
thanks buddy al just order a new kit today get it done at weekend didnt want to go threw awl that hassle to find it wasnt that as Ive done a few before and hate thum
Old Jan 21, 2010 | 06:12 PM
As said defo sounds like the pawl.
Old Jan 24, 2010 | 10:17 PM
JamesyRS's Avatar
JamesyRS
would you believe it wasnt the ratchet or pawl it was the clutch fork itself? It had the fork with rubber in and musta been giving to much play n ratchet was re adjusting each time ave changed it to the solid fork and seems to be working ok just for any future reference to guys with this problem before they take the ratchet etc out cos I know it aint nice under there from experience
Old Jan 24, 2010 | 10:33 PM
AndyST's Avatar
AndyST
You've probably inadvertently done what I suggested ie the spacer trick only in reverse, it moves the ratchet further round to a less worn area, will work for a while.
Ben26
Aug 27, 2015 08:56 PM
Bosch
Aug 23, 2015 12:31 PM
mk3 fiesta cosworth
Aug 23, 2015 10:31 AM
loughlin1
Ford Fiesta
Aug 20, 2015 10:42 PM
Bosch
Aug 4, 2015 05:14 PM
