C20LET gartrac RWD
Old Jan 19, 2010 | 08:40 PM
cozi500's Avatar
cozi500
Default C20LET gartrac RWD
Does anyone know what clutch plate to use on a RWD C20LET vauxhall conversion on a gartrac mk3 escort . Ive got the bell housing and spigot bearing but what plate do i use, its a type 9 5 speed box, do i use a rs 2000 clutch plate? please advise.
Old Jan 20, 2010 | 09:38 AM
G 74F 00's Avatar
G 74F 00
Hi not 100% sure of this but im sure iv heared that the vauxhall redtop c20xe clutch and flywheel will fit.
Old Jan 20, 2010 | 09:46 AM
cozi500's Avatar
cozi500
Im unsure as someone told me that the fiction plate has to be changed because of the amount of splines on it, it differs from the type 9 box, will have to check this
Old Jan 20, 2010 | 09:16 PM
biffy1984's Avatar
biffy1984
Why not use a Manta 1800 Getrag box and calibra turbo clutch? Manta 1800 box has a 14 spline input shaft which matches the 220mm calibra clutch.
Old Jan 20, 2010 | 11:05 PM
cozi500's Avatar
cozi500
Ive been looking for a manta box but cant seem to get hold of one, there like as rare as hens teeth. Ł160.00 for the for bell housing conversion, from RWD motorsport, but had a look at the housing, it uses the ford input shaft bearing, clutch forlk, clutch plate, but what i cant see is the opening for the forlk to mate up with the cable, theres nothing there. N opening??
Old Jan 20, 2010 | 11:18 PM
JonnyBravo's Avatar
JonnyBravo
Call Helix or Mardi Gras Motorsport They will supply you a Vauxhall fitment clutch with a Ford centre. Personally I'd put it on a T5 box now as the type 9 will be struggling with stock power from a let.
Old Jan 20, 2010 | 11:46 PM
cozi500's Avatar
cozi500
Im all confused now, should i go for the T5, cozi box and spend Ł300 + new bell housing plus clutch plate and spigot bearing, or should i go for the type 9 box which ive already got, or as someone sugested the opel manta Getrag box, can anyone advise which route to go down please.
Old Jan 20, 2010 | 11:50 PM
timrud's Avatar
timrud
Lets look at your options:
Type 9 - Will shit itself fairly quick, meaning you can either replace it now, or when it happens.
Your choices are then:
The Manta box. Not sure how strong this is, and as you already mentioned not easy to get hold of. Or the T5. Easy to get hold of, plenty strong enough. Think thats your mind made up
Ford Focus RS Parts for Sale.
Jun 2, 2016 06:46 PM
turbotrev
39
Apr 17, 2016 09:03 PM
landaqmabba
Sep 15, 2015 07:16 PM
28
Sep 8, 2015 07:10 PM
Marc sierra
12
Aug 30, 2015 10:38 AM
