Leaky radiator
Old Dec 28, 2009 | 01:54 PM
Allerz09's Avatar
Allerz09
Default Leaky radiator
Whats best to put thru a leaky radiator???? Rad Weld or K-Seal???
I'v been told by a couple of mate not 2 use Rad Weld coz it mite course problems in the smaller pipes in the system.
The car is a 1.7 puma
cheers for any advice
Martin
Old Dec 28, 2009 | 02:00 PM
Chip's Avatar
Chip
*** Sierra RS Custard ***
As anything other than a very temporary repair just replace it.
Old Dec 28, 2009 | 02:34 PM
cossiejsy's Avatar
cossiejsy
personally i wouldnt use any of that stuff and would just replace it straight away mate
Old Dec 28, 2009 | 02:49 PM
Alvyn's Avatar
Alvyn
crack a raw egg into the header tank job done
Old Dec 28, 2009 | 03:17 PM
Kalimex K Seal, unlike all the others it contains silicone, although intended as a temp cure, I personally know cars that have had it in for over 5 years still not leaked a drop, despite having anti freeze changes.
Have also used it on a nissan 4wd with a cracked(frozen) block over 10 years ago still water tight.
I used it myself when my HG went shortly after getting my car, it bought me time to get the job fixed properly but hadn't leaked a drop in 8 months with it in, after going through one winter.
It also did not block the heater matrix not a bit as it only reacts with air.
Old Dec 29, 2009 | 01:33 AM
Allerz09's Avatar
Allerz09
cheers lads n lasses, guna try it before i replace anything tho. Quite a few people i'v spoke to have sed K-Seal is the boy
Old Dec 29, 2009 | 11:58 PM
Toe Knee's Avatar
Toe Knee
not sure on rad seal blocking pipes but its doesnt last long, i know in my 306 it started leaking again badly after a short while where as in a 206 i had with a leaky rad using k seal its still going strong at least 1 1/2yrs later!!
Old Mar 17, 2010 | 10:24 AM
sponghead's Avatar
sponghead
Tabetha. Would you recommend K Seal for a 2wd saph. I lose about 500 mls per 400 miles. I suspect that is is being lost through the heater matrix due to the smell in the car usually first thing in the morning when it has been standing overnight or when i move it from a cold setting to hot.
Car loverly and warm these days by the way.
Old Mar 17, 2010 | 02:42 PM
Yes I would use it just until you get time to do a matrix swap, although I've known it last years, I just don't like the thought of relying on it.
I used it as it was winter time and didn't fancy a hg swap at the time, just to buy me some time, but can say for sure it did not block any water ways, there was no trace of it when I took the head off, even though it had worked sealing the blown hg.
Old Mar 17, 2010 | 04:06 PM
sponghead's Avatar
sponghead
Cheers mate
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
Chas
Oct 5, 2015 07:13 PM
