vibration from my cossie
Old Jan 1, 2005 | 06:03 PM
RSCossieGaz's Avatar
RSCossieGaz
Default vibration from my cossie
got a problem with my cossie when driving im getting a vibration that comes and goes but especially bad when turning left.I feeling its possible balljoint or cv joint that fooked.
Its doing my head in making the car horrid to drive any idears wot my be the cause of this ?
Old Jan 3, 2005 | 02:47 PM
mmsport's Avatar
mmsport
is it a 2wd or 4wd mate?
Old Jan 3, 2005 | 09:09 PM
Dean Saff's Avatar
Dean Saff
sounds like a bearing mate.
Jack it up and feel for play in the wheels and steering.
Old Jan 3, 2005 | 09:51 PM
RSCossieGaz
its a 4x4 m8
Old Jan 3, 2005 | 11:14 PM
Azrael's Avatar
Azrael
Check if exhaust is not hitting front prop.
Old Jan 3, 2005 | 11:22 PM
RSCossieGaz
yeah been told that but it isn't that
Old Jan 3, 2005 | 11:28 PM
Azrael's Avatar
Azrael
I hve similar problem - sometimes (very rarly) there is heavy vibration when going through very fast left hand corners but only if I'm not going very close to the limit. Very specific condition. No idea why it happens, And I can't find it out for some months now.
Old Jan 4, 2005 | 12:12 AM
RSCossieGaz
ive been told my problem mybe a cv joint but will know more when ma mate has a look at it
Old Jan 4, 2005 | 12:13 AM
Azrael's Avatar
Azrael
I have no idea how it could be, but may be....
Old Jan 5, 2005 | 02:53 PM
FoSiCo's Avatar
FoSiCo
Default same prob, vibrations while cornering 4x4 Saph
I've got the same problem with my Saph 4x4 in right hand corners. Only while or just before sliding the front wheels with the steering wheel turned more then 90°.
This only started happening after i 'renewed' my left-front driveshaft because both boots were leaky. It always drove fine & without noises or vibrations.
The one i put in came out of an Xr4x4, and was fine whilst in the Xr4x4. Only difference is that it is 15 millimeters longer than the Cossie one. But it seems to have enough tolerance, the inner spring is not fully compressed when the driveshaft is straight (car on ground).
Wheelbearings seem o.k. & exhaust is not touching the propshaft(s).
Any suggestions what might cause this vibration/noise??
Old Jan 8, 2005 | 11:39 AM
RSCossieGaz
gonna have to change both the inner/outer tca bushes on both sides that is hopefully the likely problem
gcfcos
59
Oct 6, 2015 05:04 PM
XR4
Ford XR Range
Oct 1, 2015 12:46 PM
A.t.p
Sep 29, 2015 05:04 PM
cossie330
Sep 27, 2015 04:13 PM
Russ Payne
Sep 25, 2015 08:29 PM
