Re: Ford Escort 1.8TD problem
Old Dec 12, 2009 | 07:19 PM
spangles's Avatar
spangles
Default Re: Ford Escort 1.8TD problem
I have got a 1998 Ford Escort 1.8TD estate which drives fine until intermitantly, it loses power and the engine finally stalls. It starts again fine straight away and runs fine for a while and then plays up again. It usually loses power on going up hills but not necesarially on all hills. Also the heater plug dashboard warning light flashes intermitantly whilst I am driving. I have read other posts on here about this being the engine management system warning that there is a problem and then putting the engine into safe mode but as far as I am aware my car does not have an engine management computer on board. Any suggestions as to what I can check before taking it to the garage please. Thanks
Old Dec 18, 2009 | 08:09 PM
spangles's Avatar
spangles
As a follow on now the car will not start, the immobiliser light is flashing at me and the heater plug light is not illuminating at all. Any suggestions greatfully received !!!
Old Dec 18, 2009 | 08:36 PM
cozzy jeff's Avatar
cozzy jeff
are you getting power to your heater plugs,check this first to rule them out.
matman
Sep 9, 2015 05:45 PM
dodge8283
27
Aug 19, 2015 08:42 AM
