Focus RS turbo failures
Old Nov 27, 2009 | 02:57 PM
Flipb's Avatar
Flipb
Default Focus RS turbo failures
I have bought a series 1 focus rs with around 37k miles from a reputable dealer of rs's but in less than 1 day the turbo failed. They have replaced the turbo but in only a few hours the turbo has failed again. It looks like a lubrication problem to the turbo to me but I wondered if this was a common thing that points to a bigger issue that I should be afraid of, or is this an unusual thing that has a smaller non serious problem behind it?
Any advice would be appreciated to quash my fears thati am about to have to embark on a road to ruin due to the start on a long list of issues this car may have.
Cheers.
Old Nov 27, 2009 | 03:16 PM
paceo's Avatar
paceo
Cheers.
check the oil feed to the turbo, probably starving it of oil
Old Nov 27, 2009 | 03:20 PM
Adam.'s Avatar
Adam.
Needs Beer Tokens.....
I had this problem it was the oil feed pipe, unscrew it and disonect ur ht leads from ur plugs the crank the car over to see if oil is coming out as it should be
Old Nov 27, 2009 | 03:28 PM
m4tt274's Avatar
m4tt274
bit silly of you to put another turbo on without trying to figure out why the first one failed. is the second one still under warrenty?
probably a blocked oil feed pipe.
did the 2nd turbo fail the same as the first one. its just a possiblily ur first one failed of nautral causes and the 2nd one was a duff from the factory
Old Nov 27, 2009 | 04:48 PM
Flipb's Avatar
Flipb
Cheers guys. That makes me feel better. I will get on to the garage that are working on this under the warranty. Only had in total for about 18 hours
Old Nov 27, 2009 | 05:11 PM
THEDMAN's Avatar
THEDMAN
Check the gauss inside the banjo bolt.
Old Nov 27, 2009 | 05:14 PM
Hezz's Avatar
Hezz
cant believe they didnt check if there was a problem which caused the turbo to fail!
Old Nov 28, 2009 | 11:37 AM
mk4gartrac's Avatar
mk4gartrac
Did they change the oil it may be full of crap
salsheikh
Ford Focus ST Parts for Sale
Oct 6, 2019 07:56 PM
3i Jim
Nov 20, 2015 05:12 AM
Matt Baxter
Sep 16, 2015 08:30 PM
salsheikh
Ford Focus RS Parts for Sale.
Aug 20, 2015 12:22 PM
