Reversing lights
Old Nov 25, 2009 | 04:30 PM
shauny36's Avatar
shauny36
Default Reversing lights
Could someone please tell me why my reversing lights wont work on my ESRT. All the other lights work except those . Ive checked the fuses under the bonnet and theyre all ok.
Old Nov 25, 2009 | 05:11 PM
Check the gearbox switch, with ignition turned on to pos 2 bridge the two connections on the loom plug that goes to the switch, if they now light look at replacing the switch, if they don't check bulbs are ok.
At one of the terminals at the connector you will have a live with ignition on, so if no joy above check that.
Old Nov 25, 2009 | 05:37 PM
shauny36's Avatar
shauny36
Ive checked the bulbs and theyre fine, where abouts is the gearbox switch located?
Old Nov 26, 2009 | 03:38 PM
I'm not sure on your car, but think it's on the side facing the n/s inner wing, it will be the only electrical connector going to the box anyway so can't go wrong.
stevecfrst1
Sep 30, 2015 05:18 AM
deathrider666
Sep 28, 2015 06:12 PM
Sep 28, 2015 10:05 AM
The Enigma
Sep 12, 2015 10:12 PM
