Heater on 1997 escort van
Old Nov 9, 2009 | 10:33 PM
brandy's Avatar
brandy
Default Heater on 1997 escort van
My dads heater has packed in Ive tried the fuse thats ok so i was just wondering if there is anything else simple that could be the problem or is it get the whole heater out and replace it if so how hard are they to replace?
Old Nov 10, 2009 | 07:02 AM
I would check to see if the motor is still working.Then i would check to see if there is power goong to the heater speed switch.
Old Nov 10, 2009 | 04:14 PM
As above I assume you mean the actual blower motor, rather than the heater matrix, which would of course be leaking if "packed up".
I would do as above and also check the earth at the motor itself, which on these I'm sure is on the bulkhead under the wiper linkage area, do able from under the bonnet by removing the panel/seal above motor, at rear of underbonnet area.
It's not at all unusual to lose a speed from the dial as the resistor pack packs up on 1 setting, but more unusual to lose power to the switch, on the highest(fastest speed) setting it is direct and not through the resistor pack that site on top of the motor, resistor pack merely cuts the voltage down for the slower fans speeds.
Could always run a live supply direct to the motor to make sure the motor itself is ok too.
tonicosworth
Ford Escort RS Cosworth
Oct 31, 2015 08:40 AM
3dr cossie
Alloy wheels and ICE for sale
Sep 2, 2015 08:58 PM
Bighandsuk
Sep 2, 2015 05:23 PM
