White smoke help please!
Old Nov 8, 2009 | 10:29 AM
leepeet69's Avatar
leepeet69
Angry White smoke help please!
Hi there ive got a frst and i have recently chnaged the head gasket and inlet gaskets when it was all back together i started it up and all was fine, but we noticed a slight drip of water comming from the inlet gasket where the water pipe is connected underneath ( think it goes to the water cooler on the oil filter housing) so off came the inlet manifold and fitted a genuine ford inlet gasket once it was all back together again i started in up and there was white smoke comming from the exhaust!
Note: this only started after changing the inlet gasket the second time not when the headgasket was changed!
Any ideas anyone?
Thanks lpeet
Old Nov 8, 2009 | 02:52 PM
Is coolant level going down ?, could just be due to cold temps, as they won't steam/condense till a little bit warm, did you run it longer 2nd time ?
Old Nov 8, 2009 | 06:03 PM
xr2wishy's Avatar
xr2wishy
Bodger of Blackburn
you sure this isn't just condensation?
you will get this loads fella, bigger the bore on the exhaust, the more you will get.
i get loads of comments about it on my project car, and it always clears up after a few minutes idling, or a couple when driving.
just keep an eye on coolant level and engine temp, go for a spin for ten mins or so, then look at the exhaust and be happy it's cleared up, if not H/G or turbo failure iminant.
also, bear in mind it's colder out now, so even more condensation will settle in your exhaust
bobsworth
77
Mar 24, 2016 09:30 PM
Steve Escos
Oct 1, 2015 06:57 AM
Fudgey
21
Sep 30, 2015 06:19 PM
SMILER258
Sep 28, 2015 09:04 AM
