fireing on two cylinders
Old Nov 3, 2009 | 10:27 PM
trossnova's Avatar
trossnova
Default fireing on two cylinders
my rs turbo efi is fireing on two cylinders its the two at the crank pully end, i have power going to the other two injectors closes the flywheel end and i have a spark on the two plugs on the cylinders that are not fireing other than the injectors not working can this be a fuel pressure issue or something ells??
Old Nov 4, 2009 | 12:10 PM
martysmartie's Avatar
martysmartie
Providing it's a good spark, and plugs etc are not cracked check injectors 3 and 4 earth's are switched as the injectors run constant live not earth.
Martin
Old Nov 4, 2009 | 04:35 PM
trossnova's Avatar
trossnova
how would i check this?? when i put a bult between the two terminals and turn car over it lights up
Old Nov 4, 2009 | 04:48 PM
martysmartie
Thats fine then, have you checked the condition of the injectors I.E, there not blocked?
Martin
Old Nov 4, 2009 | 05:08 PM
trossnova's Avatar
trossnova
not yet that is the next step, can i blow them out with an airline??
Old Nov 5, 2009 | 03:20 PM
NO, but a better way would be to swap the 2 known working ones with the 2 suspect ones and see if the running cylinders move with that.
Old Nov 6, 2009 | 12:06 PM
trossnova's Avatar
trossnova
ok iv had the two injectors cleaned and activated them manualy and blow air threw them so as far as i can see its not the injectors.
Old Nov 6, 2009 | 12:29 PM
martysmartie
Do you know if there is fuel coming from the rail to these two injectors?, I wonder if the phasing is out to the injectors otherwise.
Martin
Old Nov 6, 2009 | 12:42 PM
trossnova's Avatar
trossnova
phasing?? well when i pulled the two injectors out of the rail they smelt of fuel and it was dripping from the rail.
Old Nov 6, 2009 | 08:23 PM
trossnova's Avatar
trossnova
finally got it sorted some wally told me the wrong plug order
Nov 1, 2015 06:53 PM
