ST170 Inlet
Old Sep 25, 2009 | 07:00 PM
mattxr3i's Avatar
mattxr3i
Default ST170 Inlet
does the ST170 inlet manifold flow better than the High Flow alloy inlet found on the 130 specs?
Old Sep 25, 2009 | 09:08 PM
cjwood555's Avatar
cjwood555
what's the application? flow wise it's pretty good (dependent on runner position vs rpm), but doesn't take boost well.
Old Sep 26, 2009 | 07:25 AM
mattxr3i's Avatar
mattxr3i
Silver top 1.8 Zetec, with cams, ported head, omex and uprated exhaust
Old Sep 26, 2009 | 08:30 AM
mozzy's Avatar
mozzy
Ford for life
the shitter is i had one in the shed but think my old dear may have slung it out, i got the throttle body for definate but will check manifold
Old Sep 28, 2009 | 11:10 AM
cjwood555's Avatar
cjwood555
are you experiencing symptoms of inlet restriction e.g. torque flat-lining at higher rpms? if not i wouldn't bother as you'll need the imrc box connecting up to your omex to make the most of it.....
arkeye
Ford Focus ST
Feb 20, 2016 01:22 PM
Nov 1, 2015 06:53 PM
Fudgey
21
Sep 30, 2015 06:19 PM
Johnny Knoxville
Sep 30, 2015 07:21 AM
