head gasket set question.
Old Jul 7, 2009 | 08:14 PM
BAM_S2's Avatar
BAM_S2
D22 BLC
Default head gasket set question.
Quick question, just confirming that this head gasket set is suitable for early 86 3dr ????
http://cgi.ebay.co.uk/HEAD-GASKET-SE...3A1%7C294%3A50
cheers
ben
Old Jul 8, 2009 | 07:41 AM
Yes it is fine, the only thing to watch with the 3 doors is the headbolts themselves, as they used a much smaller washer under the bolt head, the later 2wd sapphy ones are physically too large to go in the holes machined in your head, some early 2wd sapphy also had earlier head type holes.
Personally I'd buy the Cometic gaskets for everything, apart from the YB0611 head gasket, I'd get these from Matt Lewis 01543 484488 07910818110.
Old Jul 8, 2009 | 10:28 AM
BAM_S2's Avatar
BAM_S2
D22 BLC
cheers mate great help there.
Old Jul 8, 2009 | 11:04 AM
cozmeister's Avatar
cozmeister
More boost Igor!
Early type is up to YBB6418, later type is obviously after. Your Cosworth (YBB) engine number is stamped above the water pump.
SmudgerByName
52
Jul 28, 2016 06:14 PM
3i Jim
Nov 20, 2015 05:12 AM
cossiedean84
37
Sep 2, 2015 10:19 PM
mint_s2
Sep 2, 2015 08:58 AM
Steve Escos
Aug 24, 2015 07:56 AM
