abs sensors
Old Jul 4, 2009 | 09:02 PM
lleewar's Avatar
lleewar
Default abs sensors
Hi My '95 scorpio has abs sensors but trying to remove them is nye on impossible . Can someone out there give me a hint on how to move them. I assume that they are just pushed in but I do not want to damage them getting them out. Also, does anyone know where I can get a cheaper than Ford(86.00) speed sensor. My speedo is playing up(staying at around 30 while doing 70) as the gearbox is having difficulties in changing gear. Many thanks in advance
Old Jul 5, 2009 | 08:21 AM
The abs sensors are indeedy a pain in the rear, but just patience I'm afraid, and a good soaking in diesel fuel will help.
I assume your car is auto, the box uses more than just the speed reading, you may have a prob with the speedo itself as if it is registering speed can't see how it can be faulty at some speeds due to the way it works, a faulty turbine speed reading will also cause bad shifts, scorpios were horrendous for wiring probs related to boxes as well.
Old Jul 5, 2009 | 11:59 AM
.Ross.'s Avatar
.Ross.
During a recent conversion I had problems getting an sensor our .. I had to inflict alot of pain on the hub to remove it.
In the end I made a puller and pushed it out.
Like said tabetha ... Plenty of lube ... Soak it in Vinigar .. Try everything to remove intact.
Once out check resistance with a Mulit-Meter .. Bound to find resistance Values on the internet.
Good Luck.
Old Jul 6, 2009 | 07:05 AM
lleewar's Avatar
lleewar
Hi Tabetha, speedo works OK on local runs/short journeys but stick it on a motorway and the speedo starts to play up. ie satnav says 70 and speedo says 40. Could oil and filter change(slightly brown,bought it like it) help the situation as well as cleaning the vss? Thanks Lee
Old Jul 6, 2009 | 12:26 PM
I would change it anyway as it is old fluid, but more likely to be electrical prob with speed issue.
Old Jul 25, 2009 | 01:45 PM
lleewar's Avatar
lleewar
Default vss
Have replaced the vss with a secondhand one. Now the cruise control seems to work but the speedo has gone the other way in so much that it now reads about 10 miles over actual speed. Checked with ford dealership and he confirmed the vss is one for my car and other vehicles like sierra, transit etc. The vss is different in body style, would this make a difference to its performance????
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
tankybaby66
Feb 6, 2016 02:24 PM
