rear cosworth brake pads problem
Old Jun 30, 2009 | 08:32 PM
luxembourgrst's Avatar
luxembourgrst
Default rear cosworth brake pads problem
hy it on my escort rs turbo i did a converstion evrey think is ok with the plats and the spacer with 2 wd calipers a 2 wd disc
the only problem i can do the calipers over all the disc it a problem about 3 mm to close the calipers
i think the pads are to big it write for scorpion and granade
thanks sorry for my english but what are the sice of rear cosworth pads thanks
[IMG]http://photomaniak.com/upload/out.php/i725614_Picture344.jpg[IMG/]
Old Jul 1, 2009 | 11:24 AM
IANS2RST's Avatar
IANS2RST
there are notches in the caliper piston one of which needs to line up with the peg that sticks out on the back of the pads
Old Jul 1, 2009 | 05:51 PM
luxembourgrst
yes they are alignet it s not that the problem
look the picture there the calipers is good but i nt close it because it s tutch the 2 sticks
it like i need to cut thema little bit 5mm +-
thanks
Old Jul 2, 2009 | 06:53 PM
luxembourgrst
up
Old Jul 2, 2009 | 08:38 PM
nicksaph's Avatar
nicksaph
hello mate
the sliders(sticks) look like the are not all the way in mate! do they move freely in and out ? is there any rust/ dirt built up in the caliper bracket holes
cheeRS nick
Old Jul 4, 2009 | 11:33 AM
luxembourgrst
every thing slide free the hole is free i took some mesure
the slider do 5.8cm maybe there are from a 4x4??? or the pads are wrong
the slider is full inside
it missing 3-4mm that the caliber can enter
help
Old Jul 4, 2009 | 01:20 PM
nicksaph's Avatar
nicksaph
hello mate,
not 100% sure but they are possably 4x4 sliders as the carrier is wider on the 4x4 to acommadate the wider(vented) disk
as far as i am aware the pads for all disk braked sierras and granadas are the same
cheeRS nick
Old Jul 4, 2009 | 05:16 PM
That slider is 100% wrong one, just cut off a bit from each end.
Old Jul 5, 2009 | 11:50 AM
luxembourgrst
is what i did and now is perfect i cut 5mm each all of them
thanks
Old Jul 5, 2009 | 04:15 PM
It's annoying when people mix bits up, glad you got it sorted.
Old Jul 6, 2009 | 03:25 AM
huangfeng's Avatar
huangfeng
not 100% sure but they new york asian escort are new york escort possably 4x4 sliders new york asian escorts as the carrier is wider on the 4x4 to acommadate the wider(vented) disk as far as i am aware new york escorts the pads for all disk braked sierras and granadas are the same
Old Jul 6, 2009 | 06:52 AM
Yes pads all the same on rear vented or not.
Gaz 88
Ford Focus RS Parts for Sale.
29
May 10, 2017 12:31 PM
Aug 14, 2015 07:29 AM
track.focus'd
Aug 12, 2015 05:53 PM
Bezzy41
Aug 3, 2015 10:31 AM
Graceland
Jul 31, 2015 10:34 AM
