xr4x4 pulsating brakes
Old Jun 12, 2009 | 07:34 PM
grahamw1604's Avatar
grahamw1604
Default xr4x4 pulsating brakes
Hi, i have just purchased a sierra xr4x4 with the intention of putting on road (it has been off road for a while!!)
Anyway, when driving the car, even just trickling down the road the brakes are pulsating as though the abs is kicking in all the time, i have removed front and rear brakes and cleaned up pads and discs and made sure pads aren't stuck, there is no gaps and pistons are coming out ok, discs do not seem to be overly bad, someon told me it probably is abs but not pump or module but maybe a sensor, i don't want to be replacing parts that don't need replacing so was hoping someone might have some experience with this
any help would be gratefully appreciated
thanks graham
Old Jun 12, 2009 | 07:39 PM
nicksaph's Avatar
nicksaph
sound like the abs mate, check all the sensor rings are clean and free from rust etc,
cheeRS nick
Old Jun 13, 2009 | 09:51 AM
As above^^ thgis is what I would do first, any rust or broken segment will cause this on the ring.
Old Jun 14, 2009 | 08:25 AM
grahamw1604
will try these thanks a lot
muzzman1
Sep 30, 2015 08:59 PM
Sp3no
Sep 27, 2015 07:23 PM
