Focus TDCI losing power
Old Jun 1, 2009 | 07:11 PM
dazza2471's Avatar
dazza2471
Default Focus TDCI losing power
Hi guys, i have just bought a 2004 Focus TDCI with 75000 miles on the clock. It has been running fine for the first 50 miles. I put some diesel in it earlier and after about a mile i pulled away from a roundabout and the car had little power and was blowing black smoke out of the back. This lasted about 10 secs then went back to normal. I left it for about an hour and took the car for a drive round the block and it did the same again for a short time then went back to normal. Any suggestions would be greatly appreciated. Many thanks
Old Jun 1, 2009 | 07:39 PM
A good thrash is usually a good idea with diesels!!
Old Jun 2, 2009 | 07:35 PM
RSricRS's Avatar
RSricRS
Long live the ford RS'S
Give it some redex from a petrol station then open her up on the motor way pal.
Old Jun 2, 2009 | 08:02 PM
Blakeya's Avatar
Blakeya
Fuel filter mate!!!
Old Jun 4, 2009 | 09:56 AM
sparks3107's Avatar
sparks3107
r sparks
fuel filter dirty fuel m8!
Old Jun 4, 2009 | 10:12 AM
GUZZLER's Avatar
GUZZLER
could also be an issue with the turbo, worth running a bottle of fuel treatment through it.
Old Jun 4, 2009 | 10:43 AM
AJ_ERST's Avatar
AJ_ERST
a split pipe will cause it to be underpowered and blow black smoke out, however it should do that all the time. worth a check though
Ford Focus RS Parts for Sale.
Mar 9, 2016 01:03 PM
Nov 5, 2015 08:12 PM
Nov 3, 2015 04:08 PM
hopper350
Sep 4, 2015 12:53 AM
Sep 3, 2015 10:49 AM
