Focus
Old May 19, 2009 | 02:28 PM
jimbob2512's Avatar
jimbob2512
Default Focus
Hi, i would like to know where the 'Inlet air temp sensor' or the 'Engine coolant temp sensor' is located in my 2008 1.6 pertol ford focus is,if you could help? (NOT FACELIFT MODEL) Thanks.
Old May 19, 2009 | 04:26 PM
Fairly sure the inlet temp sensor is on the inlet trunking between maf and plenum, think it's on the underside of the pipe.
The cts is on the stat housing.
Old May 19, 2009 | 04:54 PM
jimbob2512's Avatar
jimbob2512
Do you have any pics of that as i'm a novice at this? Thanks Tabatha
Old May 19, 2009 | 06:27 PM
pm sent
Old May 20, 2009 | 11:22 AM
jimbob2512's Avatar
jimbob2512
Hi, not been able to pick up what you have sent me. sorry bout that
Old May 20, 2009 | 03:46 PM
Daveysaff's Avatar
Daveysaff
Skint Passionford User
I hope you've not gonna put one of hose ebay 'chips' in?
Old May 20, 2009 | 06:19 PM
That is because I forgot to send it, and lost the piccie now, my dad's neighbour has the same model so will try to catch him in the morning and take a piccie for you.
Old May 20, 2009 | 06:32 PM
steves24V's's Avatar
steves24V's
Surely its still under warranty take it back to ford.
Old May 23, 2009 | 12:57 PM
jimbob2512's Avatar
jimbob2512
was goin2,can't afford a re-map.was trying to do some simple inexpensive d.i.y mods but not long had the car and can't find any info bout the engine so i can do this.i usually do what i can myself.Is there a prob with fitting 1 of these??
Old May 23, 2009 | 12:58 PM
jimbob2512's Avatar
jimbob2512
ok,thanks would be very helpful
wowk
Mar 30, 2021 07:49 PM
tankybaby66
Feb 6, 2016 02:24 PM
Sp3no
Sep 27, 2015 07:23 PM
Tank Mike
Sep 26, 2015 08:07 AM
