Brake lines
Old May 5, 2009 | 03:37 PM
turbo_bettsy's Avatar
turbo_bettsy
EFI converted
Default Brake lines
What brake lines do i need to fit cosworth 2wd brake calipers to a mk4 escort, front and rear? There needs to be banjos fitted to the front calipers so they clear.
Old May 5, 2009 | 08:37 PM
B16CVH's Avatar
B16CVH
For the fronts, i just had some made up to the original length plus a few inches and like you say with the banjo fitting. The rears, same again just had them made to around 2-3 inches longer
Old May 6, 2009 | 12:11 PM
turbo_bettsy
EFI converted
Thanks for the reply. I'll probably just go up merlin and have them made there n then.
Old May 6, 2009 | 04:26 PM
xrmalin's Avatar
xrmalin
Fronts will look like this courtesy of chris as there his old ones
mark
