mk6 rs2000 escort light problem
Old Apr 14, 2009 | 01:09 PM
webby80's Avatar
webby80
Unhappy mk6 rs2000 escort light problem
help needed my 95 mk6 rs2000 has a headlight prob , side lights work fine as do main beam but can not get dipped beam to work at all changed bulbs and checked all the fuses still no joy . you can hear a relay clicking over but not sure if its workin or which one it is
any ideas peeps????????????
Old Apr 14, 2009 | 04:59 PM
cabriolet's Avatar
cabriolet
column stalk or switch depending on what u know it as costs between 65 and 90 quid depending which one it is
Old Apr 14, 2009 | 06:33 PM
lurch1977's Avatar
lurch1977
Also the Dim/Dip relay
Old Apr 15, 2009 | 09:27 AM
webby80's Avatar
webby80
any ideas which relay it is on the board?
Old Apr 15, 2009 | 10:04 AM
Try and get someone to help, so they can press the switch etc when you put a finger on each relay(in turn) to see which one clicks, the fact that something clicks says the wiring between dip/main stalk is ok, do these ones have dim dip ?, if they do could as said be that, just try with igntion on as this sends a feed to dimp dip module when in sidelight only mode on switch if ignition is on.
Vincereese
Jun 1, 2023 09:14 AM
Vincereese
Aug 18, 2015 03:57 PM
Vincereese
Aug 16, 2015 06:38 PM
sridgett
15
Aug 3, 2015 07:26 PM
Old ford
Jul 31, 2015 06:50 AM
