ABS light on S2 keeps flickering
Old Feb 23, 2004 | 12:14 PM
Cerby's Avatar
Cerby
Default ABS light on S2 keeps flickering
Hi all.
After a bit of help with a nagging problem. After about 5 mins of driving along my ABS light keeps flickering on and off rapidly, makes a sound like a relay fooking up or something. I've had alook behind the dash to make sure there is no dodgy wiring causing a prob, all seems fine. I've had alook at the relays, but I dont know which one (if one) has anything to do with it because it stops when the car is at a stand still.
Any ideas would be bloody marvelous because Im at the min.
CheeRS in advance
Old Feb 23, 2004 | 12:36 PM
Have you checked your ABS belts are tight?
There is a sensor on the belts to warn you if they are loose.
Old Feb 23, 2004 | 12:37 PM
Cerby's Avatar
Cerby
yeah we've checked them mate, they seem fine. Ta
Old Feb 23, 2004 | 12:42 PM
How about your brake fluid level and the resivour sensor??
Not a lot more it can be mate, unless you have a faulty wire somewhere.
Old Feb 23, 2004 | 12:58 PM
Cerby's Avatar
Cerby
I've checked the fluid, thats ok. May be the sensor u mentioned then. Will try another. Cheers for the help mate
tankybaby66
Feb 6, 2016 02:24 PM
muzzman1
Sep 30, 2015 08:59 PM
