P Reg Mondeo Indicator Bulb...
Old Mar 10, 2009 | 10:40 AM
dayo05's Avatar
dayo05
Default P Reg Mondeo Indicator Bulb...
Hey guys, first post here and for good reason
i have a p reg mondeo now and the front right hand side indicator bulb has gone!
i have taken a look and cant see how to get to the bulb without having to take the wing off... is there a way around it?
Thanks in advance!!
Old Mar 10, 2009 | 11:32 AM
Gazzonator's Avatar
Gazzonator
Gary Krishna
Mk1 or mk2? They changed on the 'P'.
If its a mk2, just take the headlight out. 2 screws which hold the grille on, take the grille off, 1 or 2 (cant remember ) screws behind the grille, 1 screw by the wing at the top of the headlight and one down by the washer bottle. undo those and disconnect the multiplug and pull out the headlight and change the bulb.
If it's a mk1, the indicator lens should be held in with a clip.
Old Mar 10, 2009 | 12:15 PM
dayo05's Avatar
dayo05
Fast reply and very helpful, thank you!
it is a mk1, your help is appreciated!
wowk
Mar 30, 2021 07:49 PM
gcfcos
59
Oct 6, 2015 05:04 PM
Brickhouse
14
Oct 3, 2015 07:28 PM
The Enigma
Sep 29, 2015 10:31 AM
