T34 Turbo removal
Old Jan 31, 2009 | 01:37 PM
Dave Hewy's Avatar
Dave Hewy
Default T34 Turbo removal
Whats the best way to take the turbo off a BT Escos? The 2 bolts on the inside look nigh on impossible to get at. Is it best to take the exhaust manifold off and then remove the turbo on the bench?
Any help would be greatly appreciated.
Old Jan 31, 2009 | 06:12 PM
westus1's Avatar
westus1
its akward no matter what way you do it
the bolts from turbo to manifold are very tight to get into
but the bolts holding on the manifold are nearly as tight in places
best bet is remove manifold and replace with 2wd manifold while its off
as it flows better and makes changing the turbo in future very simple
Old Feb 1, 2009 | 11:19 AM
Dave Hewy's Avatar
Dave Hewy
Will the t34 bolt straight on to a 2wd manifold? my mate has a 2wd saff and it looks a completely different setup.
SmudgerByName
52
Jul 28, 2016 06:14 PM
Matt Baxter
Sep 16, 2015 08:30 PM
Aug 29, 2015 08:16 PM
Danielbetty
Aug 23, 2015 12:52 PM
