supercharging a focus
Old Jan 28, 2009 | 02:15 AM
Readie Si's Avatar
Readie Si
Default supercharging a focus
looking for some advice im looking at buying a focus 2.0 zetec esp and super charging it
ive found out the powerworks kit is no longer available apparently they only produce them for the ST's now
ive found a jackson racing kit available on ebay U.S
link: http://cgi.ebay.com/ebaymotors/FORD-...Q5fCarQ5fParts
how effective would using this kit be? and what else would i need to uprate? clutch pistons etc or would the oe parts be able to cope?
also whats a PCM reflash?
Old Jan 28, 2009 | 10:59 AM
percybigun's Avatar
percybigun
Twistin me melon man
i have that same jackson racing kit on my 2.0 mondeo zetec, its very good indeed.
you dont need to upgrade the pistons, its designed as a bolt-on upgrade.
the PCM reflash is the american remap method they use on alot of motors, its not compatible with ours, so you have to get your own mapping done (i got unichip on mine, cost around Ł400 including fitting and mapping on a dyno)
if you fit it with induction kit and decent exhaust you will see about 200bhp (flywheel) on a 2.0 zetec. the standard clutch is OK for about 210bhp ish, so you would be OK.
i went one step further and fitted better cams & gears, different SC pulleys (for more boost), huge cone filter, water/methanol injection, big throttle body & MAF/injectors etc and now its up to 230bhp so i got an uprated clutch (i run nitrous on top)
it is a very reliable supercharger kit, very good MPG and emissions, excellent sound etc.
the down side is that its only a small blower, and has no intercooler (and no way of fitting one) so the max power you could ever get with it (without nitrous) is about 250bhp (with all the other bolt-on mods and headwork)
if you go to www.importcarpartsplus.com and email justin, he will probably beat that price for you
Old Feb 3, 2009 | 11:55 AM
darren.cudd's Avatar
darren.cudd
if you are interested in looking at putting a rotrex supercharger on there then drop me an email as i can probably get you started on that.
wowk
Mar 30, 2021 07:49 PM
tankybaby66
Feb 6, 2016 02:24 PM
Sp3no
Sep 27, 2015 07:23 PM
Tank Mike
Sep 26, 2015 08:07 AM
