Cossie valve heights
Old Jan 24, 2009 | 10:16 AM
legend289's Avatar
legend289
Question Cossie valve heights
Anybody know what the height of the valves from the valve tip to the spring seat should be when new? I had this written down, and cannot find it now.....
Old Jan 24, 2009 | 11:30 AM
BDBCOS's Avatar
BDBCOS
I dont quite understand what you are asking. If you want the overall lengths of valves, they are as follows, inlet/ 105.68mm and exhaust /105.5mm. Spring lengths are given as 23.45mm ,valve open and 32mm valve closed. Free spring length is given as 39.8 mm. Head diameter of ex . valve is 31.0-31.2mm and inl. valve is 35.0-35.2mm. Stem diameters are , 6.970mm/6.955mm for inlet and 7.960/7/938mm for exhaust. Hope this is of some help. This info is given in The Story of The Ford Sierra RS Cosworth. It can be obtained from www.cppress.co.uk I dont know the price but it is full of engine data. I live just up the road from you so you could contact me on 02392 259358 if you need further info. My name is John. My 3 Door is with Tremona garage at the moment for a total engine rebuild. New bits so far £3800!!
Old Jan 24, 2009 | 03:21 PM
legend289's Avatar
legend289
Hi John, thanks for the info, but not quite what I need. If you put one each of the inlet and exhaust valve into the head, I need the distance from the valve tip(where the follower would sit) to the casting underneath where the spring platform would sit. This is so that I can calculate how deep to cut new valve seats.
Old Jan 24, 2009 | 04:30 PM
BDBCOS's Avatar
BDBCOS
Sorry mate. That info is not in the book.
Old Jan 25, 2009 | 05:27 PM
2001ode's Avatar
2001ode
Hi,
Is that you need ?
Regards.
Claude
Old Jan 26, 2009 | 06:01 AM
legend289's Avatar
legend289
Perfect! Thanks Claude. Is it the same on both inlet and exhaust?
Old Jan 26, 2009 | 06:37 AM
2001ode's Avatar
2001ode
I suppose, cause lengh valves and springs are identical.
Regards.
Claude
Old Jan 26, 2009 | 07:51 PM
legend289's Avatar
legend289
Thanks again Claude, very helpful.
Russ Payne
Sep 25, 2015 08:29 PM
IainRS1700T
Sep 25, 2015 06:44 AM
RS-Rikki
Sep 21, 2015 07:27 AM
rs_jim
Sep 19, 2015 08:41 PM
cossirob
Sep 3, 2015 09:17 PM
