efi fusebox
Old Jan 19, 2009 | 09:24 AM
orion88's Avatar
orion88
Default efi fusebox
so im converting from mfi to efi however the new loom i have only has the grey relay in the fuse box.
is that right?does it only use the one or is it a case of someones pulled em out?
the loom is out of an already converted efi escort turbo however the looms from a breakers yard so unsure as to whether the the relays have been removed
Old Jan 19, 2009 | 09:28 AM
Windle's Avatar
Windle
i didn;t go as far as that, simply removed the MFI loom just after the fuse box (engine side) and joined in the EFI loom to the same place. You only need the engine part i am guesing?
Old Jan 19, 2009 | 09:34 AM
orion88's Avatar
orion88
my old loom is shot tho so i want the new shiny one in theyre
but even in ur instance surely theyre was more than just the grey relay in the fuse box?did u just keep all the old relays from the mfi loom in theyre?
Old Jan 19, 2009 | 11:11 PM
Windle's Avatar
Windle
as above i never touched the relays but yes there should be more than 1! just swap your MFI ones in if your doing the full loom?
Old Jan 20, 2009 | 08:34 AM
orion88's Avatar
orion88
yea the relays are theyre in the foot well as i know the efi fuel is yellow not pink
even my 1.1 estate has more than just the one in the fuse box lol
will just put them in cant see it being a problem
155lee
Sep 6, 2016 11:10 AM
mk1turboestate
Dec 2, 2015 08:31 PM
davidfordrs
Sep 21, 2015 04:23 AM
RSmark84
Sep 13, 2015 01:29 PM
dms04
Sep 11, 2015 01:57 PM
