Noises from underneith on 3dr
Old Nov 23, 2004 | 04:19 PM
B11GNS's Avatar
B11GNS
Default Noises from underneith on 3dr
i am getting rumbling noises coming from underneith when i come of the throttle and then it goes when i put the throttle back on. It is more apparent at higher speeds, anyone any ideas?
Old Nov 23, 2004 | 04:30 PM
jon@work's Avatar
jon@work
sounds like you need a recon prop - same happened to me.
Old Nov 23, 2004 | 05:45 PM
B11GNS's Avatar
B11GNS
any idea what sort of money you're looking at for that, and what sort of place would i have to go to?
Old Nov 24, 2004 | 02:01 AM
Dilly's Avatar
Dilly
http://www.reco-prop.com
Old Nov 25, 2004 | 01:07 PM
B11GNS's Avatar
B11GNS
Cheers for that, have phoned them but they are bit pricey but if that is what needs doing then i'll have to Anyway bttt for any other possible causes, could the diff be causing it?
Old Nov 25, 2004 | 02:20 PM
swerv's Avatar
swerv
I know it sounds like im stating the obvious but have you checked the exhaust is not too close the gearbox as i had a noise on mine that didnt sound like it would be the exhaust but it was.
Old Nov 25, 2004 | 06:30 PM
B11GNS's Avatar
B11GNS
I will check this this weekend, you never know
gingeRS
17
Oct 2, 2015 09:42 AM
martynhomer01
Oct 1, 2015 12:05 AM
IainRS1700T
Sep 25, 2015 06:44 AM
pieterjan
Ford Focus RS
Sep 17, 2015 06:17 PM
rsturbo27
Sep 5, 2015 05:08 PM
