Cosworth mk2 won't start
Old Jan 14, 2009 | 09:44 PM
ali24v4x4cosworthvan's Avatar
Default Cosworth mk2 won't start
I'm building a cosworth powered mk2 Rs2000, if fitted engine wired it all up etc
Car will run for 1 or 2 secs thats it, it only runs if distrib is turned clockwise of the mark inside!
Engine timing is fine, compression 120psi, fuel pressure 45psi, excellent spark, fitted new TDC sensor, Phase sensor and ignition module
i pulled out injector rail the don't seem to be firing quite right, any way of checking sensors, what about a self test?
Old Jan 15, 2009 | 09:02 AM
costina's Avatar
costina
Live long and prosper!!
www.bigturbo.co.uk
Paul
Bailes1992
Aug 16, 2015 07:14 PM
Aug 14, 2015 07:29 AM
track.focus'd
Aug 12, 2015 05:53 PM
Old ford
Jul 31, 2015 06:50 AM
