Focus MK2 Fuel consumption
Old Jan 6, 2009 | 05:02 AM
anachorai's Avatar
anachorai
Default Focus MK2 Fuel consumption
Hi My first post, can someone help?
I have a dealer (and Ford!!!!) Who are refusing to acknowledge that there is a fuel consumption problem.
On a full tank I am getting up to 200miles when using 3/4 of the tank. Ford say this is normal. Surely this can't be right? They claim that about 20-25mpg is correct!
Is this a known problem with the Focus? A firend of mine had a similar problem on his MK1 Focus and they eventually replaced something behind his dashboard and cured the problem.
The dealer I have say that their diagnostics do not show any issues with fuelf consumption. Is this an engine management problem?
Helllllllllllllllllllp!!!
Old Jan 6, 2009 | 05:07 AM
Benni's Avatar
Benni
Ban[B][/B]ned
You need to specify the engine and spec.
Benni.
Old Jan 6, 2009 | 05:17 AM
anachorai's Avatar
anachorai
1.6 litre Duratec
Old Jan 6, 2009 | 06:44 AM
wide ka's Avatar
wide ka
town driving, short journeys? how much does it cost to fill the tank?
Old Jan 6, 2009 | 06:57 AM
Dave Henshall's Avatar
Dave Henshall
depending upon how you drive it - i'm geting 330 miles to a tank (50 litres) in my 2.5T ST.
Old Jan 6, 2009 | 07:52 AM
Unless driven foot on the floor always or permanently in town that is bad.
My dads mk1 mondeo AUTO 2L does 30mpg always but up to low 40's on a run.
I can't see how anything behind the dashboard could affect mpg, readings yes.
The only true way to determine mpg is to fill full, run it till it's dry, then refill and work it out(on cost of refill), obviously you ned to carry a can of petrol with you for when it runs out.
Most though do a set distance after filling full and use the same station to top up full again then do it that way as it's a lot easier.
Old Jan 6, 2009 | 08:10 AM
anachorai's Avatar
anachorai
Thats what I do, I reset the trip meter, fill the tank and when the needle is on the full line, reset the meter again. The tank is 55L so it costs just under £50 to fill from empty so thats how I know how much fuel is going in.
I am never going over 55-60 mph so it isnt being thrashed.
The thing that was replaced on a friends car is a part of the engine management system.
Old Jan 6, 2009 | 09:43 AM
kaking1982's Avatar
kaking1982
i would expect between 35 - 40 mpg out of one of them
Old Jan 6, 2009 | 09:50 AM
anachorai's Avatar
anachorai
I finally managed to get a phone number for Ford's UK .......... What a trial that was, it is as if they are hiding from people.
It appears that the Powertrain Control Management system needs updating, and the "Calibration of something" needs resetting.
They think that may help!
Technoballe for "switch it off turn it on" I think
Old Jan 6, 2009 | 12:21 PM
It's just a routine update, make sure you are happy after they have done it, as a few times it can affect performance on some ford models for the worse.
It will no doubt update automatically as they plug in anyway.
salsheikh
Ford Focus ST Parts for Sale
Oct 6, 2019 07:56 PM
kyle_st200
Ford Focus Diesel
Aug 21, 2015 09:28 PM
salsheikh
Ford Focus RS Parts for Sale.
Aug 20, 2015 12:22 PM
kyle_st200
Ford Focus (All Models)
Aug 7, 2015 06:06 PM
Old ford
Jul 31, 2015 06:50 AM
