PRESSURE
Old Jan 5, 2009 | 09:11 PM
XRSTI's Avatar
XRSTI
Default PRESSURE
2 wd cossie greens,3 bar,500 cooler ,t3 dont know what chip is in it, its boostin at 14 psi what can i safely turn this up to? also just got an adjustable fp regulator with gauge, what should this be set to....... cheers
Old Jan 5, 2009 | 09:13 PM
clarke5700's Avatar
clarke5700
YES I KNOW I CANT SPELL
the boost can be terned up to a safe leavle of the chip if you have not got a clue what the chip is would say get a afr gauge and keep an eye on it.
Old Jan 5, 2009 | 09:48 PM
*Bri.4.b.Cos*'s Avatar
*Bri.4.b.Cos*
Find out who's chip it is and they will tell you. Bin the FPR or sell it on as will almost always end in tears
Old Jan 6, 2009 | 07:59 AM
As said need to know what chip maker/writer says with regard to boost, fuel pressure.
The fuel pressure has no doubt been on a std pressure regulator when the chip was written so it needs one of these as if they have different rates on boost off boost it will throw the fuelling out.
At the very least find out whos chip it is and ask, or get it on a rolling road, might save you a engine.
Nov 1, 2015 06:53 PM
Fiddy
21
Sep 29, 2015 06:10 PM
SMILER258
Sep 28, 2015 09:04 AM
pabloXR
Sep 21, 2015 12:42 PM
Dubs44
Sep 19, 2015 06:31 AM
