RS1600i suspension???
Old Dec 10, 2008 | 09:43 AM
Stoogey's Avatar
Stoogey
Default RS1600i suspension???
hey i have a mk3 xr3i and was wondering if the rs1600i suspension is any different? (lower, stiffer) thanks
Old Dec 10, 2008 | 05:08 PM
Stoogey's Avatar
Stoogey
anyone help?
Old Dec 10, 2008 | 05:30 PM
Ade's Avatar
Ade
Fast Ford snapper
You're far better to just get a new lowering kit with shocks & springs.
Main thing is the XR3i has single bolts struts, RS1600i has two (different inner wings).
They were meant to be slightly stiffer from new but now at 20+ years old you wouldn't be able to tell the difference!
RS1600i front anti roll bar will go straight on though and is a proper bit of kit
Old Dec 10, 2008 | 06:13 PM
Stoogey's Avatar
Stoogey
cheers for that mate could of lost abit of wedge then thanks
Old Dec 11, 2008 | 07:25 AM
As said they were lower/stiffer but would do as suggested with spring/shock kit.
Old Dec 11, 2008 | 08:22 PM
MarkN's Avatar
MarkN
Some XR3i's had two bolt strut tops and some RS1600i have single bolts. It all depends on whether the car was made before or after May 1983. The two types are not really interchangable. I think the front springs are the same, but the spring cup was mounted an inch lower on the strut. The rear springs are shorter on the RS.
The anti roll bar is the same regardless of which strut tops the car has. The 16i version is alloy as opposed to the S1 Turbo one which is steel. I couldn't believe the difference it made when I fitted a turbo anti roll bar to my car...
Nov 1, 2015 06:53 PM
Benleys
Escort Range
Sep 28, 2015 01:56 PM
SMILER258
Sep 28, 2015 09:04 AM
