Cossy injectors
Old Dec 4, 2008 | 04:44 PM
juffer's Avatar
juffer
Default Cossy injectors
Hi all,
What size are the standard "yellow" cosy injectors and at what power level do they need changing?
thanks
Old Dec 4, 2008 | 05:31 PM
pa_sjo's Avatar
pa_sjo
Colossal Pervert
About 270cc/min iirc? You'll want something bigger past 250bhp on a YB.
Old Dec 4, 2008 | 05:43 PM
sexr3i's Avatar
sexr3i
isn't it
As above pretty much, think the part no suggests 280 cc though from memory. You want a bit of safety margin though.
Old Dec 4, 2008 | 06:25 PM
juffer's Avatar
juffer
What would you suggest for 350-400bhp?
Old Dec 4, 2008 | 06:26 PM
Weeksy's Avatar
Weeksy
I would say greys, but some get away with Light blues I believe.
Correct me if I am wrong dudes
Old Dec 4, 2008 | 06:28 PM
LHD220Turbo's Avatar
LHD220Turbo
greys or siemens blacks
you'll have to change the chip anyway so i would go for siemens blacks and go for 83lb as they are the same price as 72lb & 55lb
that way if you want more power in the future you wont have to change injectors again
83lb will do enough for circa 500hp
Old Dec 5, 2008 | 07:37 AM
Yellows will do 280bhp no problem, mine did 277, at std rail pressure.
I would use greys for the 350-400, I have 375, with stacks of duty left and a 100% spot on tickover.
mk3ste
Oct 17, 2021 10:09 AM
Mark_
14
Jan 16, 2016 05:27 PM
Nov 1, 2015 06:53 PM
gcfcos
59
Oct 6, 2015 05:04 PM
XR4
Ford XR Range
Oct 1, 2015 12:46 PM
