turbo box / slippa???
Old Nov 23, 2008 | 05:05 PM
lil dan B19 XRT's Avatar
lil dan B19 XRT
Default turbo box / slippa???
my frend has told me that you can tell if you have got a turbo box bye taking the drive shafts out off the box if you can see straight through its got a slipper in it...... how true is this???
Old Nov 23, 2008 | 05:06 PM
B16CVH's Avatar
B16CVH
Very! hehe hows it goin shag, Got that engine in yet??
Old Nov 23, 2008 | 05:07 PM
B16CVH's Avatar
B16CVH
This is what it should look like
Old Nov 23, 2008 | 05:39 PM
lil dan B19 XRT
Default box
thats sound thn i aint gona use that box of clarks thn man,its in the shed in bits now head gasket had gone so i took the head off with intension of just doing the gasket.but the valves was propa coverd in sum hard shit so we av striped the head and cleand it all up just cleanin the valves up now,clarks coming round in the week cuz iv bost 1 ov the head bolts off int the block,but over thn that its all safe should be in the festa in no tym
Old Nov 23, 2008 | 05:49 PM
B16CVH's Avatar
B16CVH
Is the bottom end sound? Bores, Bearings etc....??
Old Nov 23, 2008 | 05:55 PM
lil dan B19 XRT
ye man looks it.iv ad the sump off and it all turns over sound and there wor no bits ov shit in the bottom ov the sump im gona rebuild it anyway i fink,just to be on the safe side
Old Nov 23, 2008 | 06:04 PM
B16CVH's Avatar
B16CVH
I would to be honest, least you know is gonna be reliable if you do.
You having any work done to the head before you put it back on or are you leaving it standard?
Old Nov 23, 2008 | 06:31 PM
lil dan B19 XRT
gona leave it standaerd i fink duno yet tho man,wat do u finks best
Old Nov 23, 2008 | 10:29 PM
Raj_FRST's Avatar
Raj_FRST
Half Rice Half Chips
have you thought about having a go at a bit of proting yourself? Im in the same boat as you, my head is stripped waiting to get cleaned at the headshop, but my dremel is calling out at me.lol Im too scared though in case i feck summit up
Old Nov 24, 2008 | 11:26 AM
B16CVH's Avatar
B16CVH
Well if you wanted to go big power further down the line then it would be advisable to do it (as the head is off) but it aint cheap
Old Nov 24, 2008 | 11:29 AM
B16CVH's Avatar
B16CVH
Its quite a time consuming job that takes a lot of skill,it takes me a bout 3 or so days to get one right, even moreso if the manifold require matching but you cant just attack it and hope for the best! It is satisfying though once its done and that graph shows you all your hard work was worth it!
3i Jim
Nov 20, 2015 05:12 AM
Matt Baxter
Sep 16, 2015 08:30 PM
