Coolant System
Old Nov 17, 2008 | 04:11 PM
alexno1dj's Avatar
alexno1dj
Default Coolant System
Whats the best way to entirely flush the coolant system?
Do you drain it from the lowest point on the radiator?
cheers
Old Nov 17, 2008 | 04:26 PM
alexno1dj's Avatar
alexno1dj
wana get all the crap out of it. Its prob irrelevant, but its a 1.8 d
Old Nov 17, 2008 | 06:43 PM
The best way is to run around with WYNN's rad flush in for a few hundred miles first, it will push all the crap into the expansion tank, I normally get half a mug full, which all has to be cleaned out, this way the whole system is cleaned out properly.
Old Nov 17, 2008 | 07:26 PM
Dangerous Malcolm..'s Avatar
Dangerous Malcolm..
The block should have a drain on it too.
Old Nov 19, 2008 | 11:34 PM
alexno1dj's Avatar
alexno1dj
ahh right, probably somewhere near the water pump?
Old Nov 20, 2008 | 07:18 PM
Aaroncast's Avatar
Aaroncast
Some people re- fill with bottled water also!!!(no joking-less impurities) but is it -ott
Old Nov 20, 2008 | 07:26 PM
B16CVH's Avatar
B16CVH
Higland spring or Volvic??
Old Nov 21, 2008 | 01:22 PM
ikarma70's Avatar
ikarma70
good stuff is that wynns rad flush/holts speed flush,i used it when i was servicing my last car(rover 45ixs),kept it in for 48hrs and drained the system,flushed the rad out with a hose pipe at low pressure from the top with both rad hoses off then refilled with fresh water and ran the motor to get any muck out missed by the wynns/holts flush for 15 minutes and drained and refilled the system with fresh coolant.
however the speed flush did find a big leak in the water pump but im glad it did
Nov 1, 2015 06:53 PM
Turbo1994
Ford Escort RS Cosworth
Oct 17, 2015 10:32 PM
XR4
Ford XR Range
Oct 1, 2015 12:46 PM
Botts
Sep 22, 2015 02:04 PM
