What spark plugs
Old Oct 29, 2008 | 09:00 PM
raggey's Avatar
raggey
Default What spark plugs
Hi chaps.
Could someone tell me what type plugs and gaps size is the best for a 2lt yb cosworth,
It has a 330 chip 3bar map sensor greens and a s111 turbo technics hybrid turbo, T/technics say turbo good for 300/310bhp set at 18psi thats as high as they will warranty it for.
Paul.
Old Oct 29, 2008 | 09:28 PM
Kverna's Avatar
Kverna
Virgin-popper
BCR8ES with 0.6 gap
Old Oct 30, 2008 | 03:05 AM
Rax's Avatar
Rax
mines running about the same and i have ngk bkr9eix iridium plugs.my old ones were gapped at .75 where as i have gapped my new ones at .65.i havnt used it yet so i dont know if its going to be any better.at .75 it only ever give me a problem once on boost in 3rd,but on the advise of someone else i was told to gap my new ones at .65.
Old Oct 30, 2008 | 07:22 AM
KSA-Cossie's Avatar
KSA-Cossie
Denso IK31's.
Old Oct 30, 2008 | 08:48 AM
I'd go with IK31 too, good plug, gap is dependant on coil being used, wider does not mean better, wider gaps came about to ignite weaker eco freindly fuel mixtures.
I have a ACCEL coilpack on my sapph and gapped at 0.5mm, on std 3ms coil time.
The difference with the ACCEL coilpack is very significant especially low down and when cold, about £65 but well worth it.
Old Oct 30, 2008 | 09:22 AM
Kverna's Avatar
Kverna
Virgin-popper
I waited for you to post your pro-IK31 answer
Old Oct 30, 2008 | 01:27 PM
I can only say I have had no issues with them, they seem pretty resistant to fouling, as I drive like an old grandad sometimes, and they never do anything but behave right.
I had some 071's in there at one time, they did the job ok, but just seems more eager with Ik31, if on coilpack though I can defo recommend a ACCEL coil part number 140018, this is the early type coilpack, about 40% more energy and according to the blurb better spark duration, certainly makes a difference though, as I am looking now for one for my other halfs astra.
Old Oct 30, 2008 | 01:57 PM
Kverna's Avatar
Kverna
Virgin-popper
Yep, therefore I'm switching my standard answer to IK31
Old Oct 30, 2008 | 08:37 PM
raggey's Avatar
raggey
I forgot to mention I have also a group a coil so is the spark plug the same, also im a bit unsure about what the plugs are called do I just ask for pro ik31s or what ever
Old Oct 30, 2008 | 08:53 PM
Kverna's Avatar
Kverna
Virgin-popper
Doesn't make any difference.
Ask for Denso IK31 or NGK BCR8ES
tankybaby66
Feb 6, 2016 02:24 PM
Nov 1, 2015 06:53 PM
A.t.p
Oct 23, 2015 07:54 PM
Brickhouse
14
Oct 3, 2015 07:28 PM
deathrider666
Sep 28, 2015 06:12 PM
