plenum chamber connections
Old Sep 30, 2008 | 08:02 PM
proboscus's Avatar
proboscus
Default plenum chamber connections
ive just fitted an oil separator there is a union that bolts into the plenum cover a pipe from this went to the old kidney box as there is now nowhere to connect this pipe tp do i just block the pipe off?
Old Sep 30, 2008 | 09:00 PM
LHD220Turbo's Avatar
LHD220Turbo
once you've removed the kidney box and all the pipes that go into the kidney box, you will be left with a hole in the block. you will need this adapter to fit into the hole http://cgi.ebay.co.uk/RS-Cosworth-Pi...d=p3286.c0.m14 you will then need a new piece of pipe to fit onto the adapter and long enough to reach the top right outlet of the breather pot
you will then need to drill your cam cover and fit this adapter http://cgi.ebay.co.uk/RS-Cosworth-Al...d=p3286.c0.m14 then run a small amount of hose from the cam cover adapter to the top let outlet of the breather pot
you will then need to fit this adapter http://cgi.ebay.co.uk/cosworth-breat...d=p3286.c0.m14 which screws into the block, turbo side (this is capped off from factory). - A new pipe is needed to be run to the smaller outlet on the bottom of the breather pot from the adapter once fitted
finally the last outlet on the breather pot (the biggest in diameter) vents to the atmosphere
you dont need to block anything off, as there shouldnt be anything to block off!
Old Oct 1, 2008 | 03:57 AM
Those adaptors sure are expensive for what they are.
Old Oct 1, 2008 | 04:12 AM
stevecossy's Avatar
stevecossy
I got all the adaptors with the fitting kit from pro alloy, the plenum pipe i got a plastic bung with the kit which screws into the plenum to block it off.
Good luck. steve
Mark RS
Oct 12, 2015 06:01 AM
stevecfrst1
Sep 30, 2015 05:18 AM
timsrs
22
Sep 24, 2015 08:14 PM
Flatlinedan
Sep 18, 2015 12:41 PM
