Intermitent esc cos volt meter???
Old Nov 7, 2004 | 10:57 AM
A.Moore's Avatar
A.Moore
Default Intermitent esc cos volt meter???
Until recently my pod volt meter was working fine.Now it's intermitant, is this a common fault? How can i test it? How do you remove the pod? Thanks Al.
Old Nov 7, 2004 | 11:48 AM
Azrael's Avatar
Azrael
Default Re: Intermitent esc cos volt meter???
That is described in Workshop Manual luckyly. It is avalible in Technical Archives section I think.
Anyway if you can't find it (and it's worth it) I can write you overall descibtion. You must look under Cosworth badge on your dash.
Old Nov 7, 2004 | 02:42 PM
A.Moore's Avatar
A.Moore
Thankyou jakub.I'll have a look.Al.
Old Nov 7, 2004 | 09:35 PM
velocity's Avatar
velocity
relay R4 and fuse number 2 looks after that meter and believe it or not the power supply to switch the relay on and off (terminal 86) comes from the abs control computer from pin 32 via the ABS pedal travel sensor/brake light switch theres a normal earth through terminal 85.you should have battery voltage at terminal 87 which is fused by fuse #2, and terminal 30 supplies the voltmeter
hope all that makes sence to you
Old Nov 16, 2004 | 12:36 AM
A.Moore's Avatar
A.Moore
Wow velocity.....i'm shocked and humbled by your knowledge.Thanks.Al.
Old Nov 16, 2004 | 08:26 PM
velocity's Avatar
velocity
its easy when you have the wireing diagram in front of you
Nov 1, 2015 06:53 PM
gingeRS
17
Oct 2, 2015 09:42 AM
A.t.p
Sep 29, 2015 05:04 PM
kevin36
Sep 9, 2015 11:12 AM
kevin36
Sep 8, 2015 12:23 PM
