Stage 3 Head Conversion
Old Aug 23, 2008 | 08:16 PM
S1Luke's Avatar
S1Luke
Default Stage 3 Head Conversion
Hi guys,
Currently one of my S1 engine's is running just under 200bhp with 18psi boost. It has a standard head and internals. I've been offered a stage 3 head. Can anyone tell me what power increase I could expect if I fit a stage 3 head? Also will there be any bad effects e.g increased lag? and will I need any remapping etc after fitting it, or is just a case of swapping the head and off you go?
Thanks very much in advance for your help.
S1Luke
Old Aug 24, 2008 | 12:24 AM
s1cab's Avatar
s1cab
whats been done to this other head? as in over sized valves, cam, ported & polished, lifters, springs, vernier?
Old Aug 24, 2008 | 08:26 AM
S1Luke's Avatar
S1Luke
It's got oversized vavles and will run on my piper cam.
CheeRS,
S1Luke
Old Aug 24, 2008 | 08:32 AM
clarke5700's Avatar
clarke5700
YES I KNOW I CANT SPELL
as with any mod done to any car its best to to have it set up. more so on a turbo car. and as your running 18psi on standared internals your on borrowed time imo.
Old Aug 24, 2008 | 08:37 AM
pa_sjo's Avatar
pa_sjo
Colossal Pervert
It will make it less responsive, but will allow higher peak power.. but if your engine isn't going to flow that air, due to a small turbo or weak internals, then it's pointless. To be honest, on a 1.6 you really need a low-comp steel bottom end and a large turbo to truly benefit from a ported big-valve head.
Old Aug 24, 2008 | 11:32 AM
s1cab's Avatar
s1cab
anything done to bottom end??
Indyrs
Dec 4, 2022 12:39 PM
Dave_b
Ford Focus (All Models)
Oct 13, 2015 05:48 PM
IainRS1700T
Sep 25, 2015 06:44 AM
wheelwizardrefurbs
Sep 18, 2015 02:39 PM
Chopshop85
Sep 18, 2015 06:13 AM
