kenlowe fans
Old Aug 11, 2008 | 06:25 PM
zvhturbo29rs's Avatar
zvhturbo29rs
Default kenlowe fans
is there any issue with using a ten inch fan with a six inch one??cheers
Old Aug 11, 2008 | 07:45 PM
peachy's Avatar
peachy
In which way??? both together??
Old Aug 11, 2008 | 08:36 PM
zvhturbo29rs
Default fans
yeah basicly i have a ten inch fan on the rad at the mo and wanna add another one to aid cooling but only six inch will fit. is it ok to run the two differewnt sizes 2gether.cheers mate
Old Aug 12, 2008 | 10:02 AM
peachy's Avatar
peachy
If the cable and fuse are rated to run both fans (the current required) then i dont see why not. Alot of people run 2 fans be it Kenlowe or what have you. If the cabling is under-rated then this can cause fires with the heat generated in the cable melting the pvc sheath.
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
Chas
Oct 5, 2015 07:13 PM
rs_jim
Oct 3, 2015 11:37 AM
simonmcf
Sep 22, 2015 08:40 AM
mk1focus
Ford Fiesta
Sep 21, 2015 05:46 PM
