escort rs turbo
Old Aug 10, 2008 | 04:15 PM
lee206v824's Avatar
lee206v824
RS Turbo Lee
Default escort rs turbo
i have recently bought a rs cabbie and it has a few problems, first off the heater controls dont work, there is no boost on the turbo (no vac leaks) and a rather loud tapping sound which has only just started, and also the car overheats when driving slow, i changed the thermostat and flushed the rad
Old Aug 10, 2008 | 05:02 PM
supermanrs's Avatar
supermanrs
rs turbo newbie
try the acuator for the boost problem and check to see if the fan is cutting in, if not change the fan switch.
Old Aug 11, 2008 | 04:27 PM
lee206v824's Avatar
lee206v824
RS Turbo Lee
the rad runs off a switch in the car and is constantly on, been told the head gasket might have gone. sorted the actuator had come loose and the split pin missing, cheers any1 no the gap for the tappets?
Old Aug 11, 2008 | 04:43 PM
project rs's Avatar
project rs
are you running a special cam if not they are hydrolic (self adjust)
3i Jim
Nov 20, 2015 05:12 AM
Matt Baxter
Sep 16, 2015 08:30 PM
FlashRS
Sep 14, 2015 12:36 PM
muz
Aug 16, 2015 12:57 PM
adriansaleem
Aug 1, 2015 09:28 PM
